TwinTurbo.NET: Nissan 300ZX forum - After High Pressure Hose Removal....
Subject After High Pressure Hose Removal....
Posted by fluidmotion on July 21, 2008 at 8:17 AM
  This message has been viewed 100 times.
Message So, I replaced my PS high pressure hose on my 91 TT and it still seems to be leaking in the two spots (on the rack and fromt he pump). It is leaking much less than before the replacement, but I was wondering if I should have replaced the copper washers?... I used the original ones, thinking they wouldn't be a problem....
Or did I just not tighten it down enough? I didn't have time to look at exactly what was leaking yet though, I'm just assuming its the high pressure hose still, because it is the only PS hose connected in those 2 spots I believe....
Also, I was wondering if you haven't started your 300zx in about 2-3 months, does a decent amount of white smoke come out (running lean?) and then just go away after running it for a while.
Thanks for the help...
